Inventor Publisher
Inventor Publisher
Active Contributor
hagiographa
Message 1 of 3 (265 Views)
Insert file failed. Failed to load assembly due to the problem with child files.
265 Views, 2 Replies
10-18-2011 07:12 PM
Why does Inventor Publisher have trouble loading Inventor Pipe Run files?
The other message about Content Center files is "File not found."
The inventor assembly has no problem with any files, so why won't Inventor Publisher open the assembly?
Employee
rajkumar.ilanchelian
Message 2 of 3 (261 Views)
Re: Insert file failed. Failed to load assembly due to the problem with child fi
10-19-2011 11:39 AM in reply to: hagiographa
When you select the assembly file (not insert just select) to be inserted, an options button is now active. Select this and browse to link your ipj file. This should solve the issue.
-Raj (Autodesk)
Active Contributor
hagiographa
Message 3 of 3 (229 Views)
11-09-2011 02:36 PM in reply to: rajkumar.ilanchelian
The 'option' to link to the project file worked for the smaller assembly I have.  (All the parts were in the project folder).
But in the larger assembly, I have content center pipe run parts (elbows) that 'fail'.
I also have the problem of having used parts and assemblies that are not in the project folder.
Inventor lets me browse for these files each time I open the assembly, but I do not have this option in Publisher.
