Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Insert file failed. Failed to load assembly due to the problem with child files.
2 REPLIES 2
545 Views, 2 Replies
Why does Inventor Publisher have trouble loading Inventor Pipe Run files?
The other message about Content Center files is "File not found."
The inventor assembly has no problem with any files, so why won't Inventor Publisher open the assembly?
2 REPLIES 2
rajkumar.ilanchelian
When you select the assembly file (not insert just select) to be inserted, an options button is now active. Select this and browse to link your ipj file. This should solve the issue.
-Raj (Autodesk)
in reply to: rajkumar.ilanchelian
The 'option' to link to the project file worked for the smaller assembly I have.  (All the parts were in the project folder).
But in the larger assembly, I have content center pipe run parts (elbows) that 'fail'.
I also have the problem of having used parts and assemblies that are not in the project folder.
Inventor lets me browse for these files each time I open the assembly, but I do not have this option in Publisher.
