Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
How to mark an object's original position on autodesk inventor publisher?
2 REPLIES 2
1188 Views, 2 Replies
Hi I have created a model on autocad which I have imported into autodesk inventor publisher...for my project I have to simulate an object's assembly and subsequent dissassembly. But to begin with my model is assembled so i have exploded it and now I want to put it back together - however I can't get the program to remember the position each component was originally in so when i try and move each component back it's all over the place and looks awful. Is there a way to mark an object's intial location so that i can move it back to exactly that place?
Any help is very much appreciated
2 REPLIES 2
RajkumarIlanchelian
Select a component and you should see the "Restore Home" command active in the ribbon. This will take the component to the initial home position. Hope this helps.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
in reply to: RajkumarIlanchelian
ah great thanks man!!
