Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Flashing black screen when running the Detail View Snapshot
16 REPLIES 16
Message 1 of 17
1664 Views, 16 Replies
Hello!
I alredy created case in technical support about month ago. Then the problem was solved and case was closed. But now the problem there is again.
___
In Publisher 2013 when I run the command Detail View Snapshot window will flash black. When I run the command in the Detail View Snapshot Publisher 2013 window will flash black. The program begins terribly slow.
This flash are very short-lived, but I was able to make some screenshots.
__
Technical specialist recommended me to update video driver. Now I have last updated driver, but problem there is.
I cant work with product. Please help.
16 REPLIES 16
Message 2 of 17
irene.chen
Could you please provide the information to us below?
- Which OS are you using, Win732, Win764, or Win8?
- Which graphics card are you using to reproduce this issue?
- Is there any special steps?
Irene Chen
Inventor Publisher QA
Message 3 of 17
bowen192
in reply to: irene.chen
I get this all the time.
90% of the time it is when using Detail Views.
It is not exclusive though.
It will often remain a blank screen until I move the model, but it will go as quickly back again. Some models I have, I have to plan my work based on this problem occuring.  It is more likely to occur on bigger files.
I use W7, Quadro 2000.  I have no problems with running Inventor and a host of other programs on the same computer.
Message 4 of 17
Windows 7 64-bit SP1, Installed all last  updates
Intel Core i7-3770K 3.50GHz
8 GB RAM
NVIDIA Quadro 2000, driver version 311.35
I check other assembly and one part for this error, but can’t reproduce it. But, if I load the Arbor Press assembly and get error, after that I can load any other assembly and get error too.
I think its problem of this specific assembly, but not sure…
Could you verify my assembly to check for error?
Message 5 of 17
bowen192
Is the specific assembly causing the problem a large file or have Detail Views?
Message 6 of 17
in reply to: bowen192
If I dont use Detail Views the problem there isnt.
I cant trace the pattern in error.
Message 7 of 17
irene.chen
Thanks for your information, I did the validation with the file you provided. it works ok at my side.
I should be caused by graphic card, did you upgrade the driver of NVIDIA Quadro 2000 to latest one?
-Irene
Message 8 of 17
Yes, I told with Autodesk technical support and first that they offer is update driver=)
I updated and problem was solved. BUT! Few days ago I open Publisher and get this problem again.
 I reinstalled driver but nothing changed.
Message 9 of 17
bowen192
I installed the Performance Driver instead of the regular driver, and this seems to have solved any issues:
http://www.nvidia.co.uk/object/quadro-tesla-win8-win7-winvista-64bit-311.35-whql-driver-uk.html
Message 10 of 17
I have already installed this driver..
Message 11 of 17
irene.chen
This is really a good news to me, Thanks for your feedback.
Irene Chen (irene.chen@autodesk.com)
Message 12 of 17
bowen192
It's started doing it again now, just as bad.
It is doing it under exactly the same circumstances.
Oh dear.
Message 13 of 17
Does anyone know if any solutions for this problem has been found? We have an up to date (SP3) Publisher installation and the blinking black screen is creating some real problems for us. It most likely has something to do with the graphics driver since we've been able to temporarily fix the problem by removing one display from our two display configuration. The graphics card model is Geforce FX4000 with latest drivers.
We also have another annoying problems which is the Word Add-in going in to Office "hard disabled" list all the sudden, and it can be enabled for an hour or so only by reinstalling it.
Publisher has not a been a very smooth experience so far.
Message 14 of 17
bowen192
Any update on this?
I am 100% convinced the problem relates to annotations.
Message 15 of 17
sepfs
my company recently bought Inventor Publisher 2013 R1 and I also had major issues with screen flickering when inserting arrows or detail views.
My machine is an I3, 16 Gb RAM, 120 GB SSD and an NVIDIA Geforce 630 GT.
I was really desperate when I tried fiddling with the NVIDIA Settings. I used a program specific configuration sow that the general setting for the rest of my programs can stay as they are.
Mainly I set:
Anisotropic filtering: OFF
FXAA: OFF
Antialiasing: OFF
Triple Buffering: OFF
Anisotropic optimisation: ON
Negative LOD Bias: Accept
Texture quality: Performance
Triliniear optimization: OFF
Threaded optimisation: AUTO
Vsynch: ON
Other than that I set the energy options of my machine to highest performance.
Now I was able to actually work with Publisher without having to restart due to the screen flickering as soon as I started using some of the tools.
Maybe this will help for some of the people with flickering issues.
Good luck!
Stefan
Message 16 of 17
bowen192
in reply to: sepfs
Interesting.  Will give it a go.
Cheers, sepfs.
Message 17 of 17
sepfs
Bowen, you are welcome 🙂
I have attached 2 screenshots of the settings. It is in German and I do not know if all the translations for the options were correct. Now you can cross-check with the screens.
I hope the issue is gone forever but when reading through the forums it seems that some issues can become "immune" to certain procedures after a while. So, let us hope the best maybe it can even help with your issues.
Best of luck!
