Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
File size of 3D PDF from Publisher 2011 R1
3 REPLIES 3
guyh
637 Views, 3 Replies
First off I'll say I know the 3D PDF support is something we should thank Autodesk for as Adobe are poor in this area.  However for my needs it is not a feature I can use.  The reason for this is the file size output is to large!  I can save my large assembly as a STEP file an import into Acrobat Pro Extended giving a file size of about 3mb.  The same assembly in Publisher will create a 3D PDF file size of 70mb.  For me to be able to convince our company to invest in Publisher this will be an issue.  It's a shame as I wish I could as 3D PDF documents are exactly what our company wants to produce.
Is there a reason the file size is so big?  Can I change settings to improve it?
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
3 REPLIES 3
Jon.Balgley
in reply to: guyh
Hi --
Can you send me some files that show the file "bloat"?  It's always best to be working from the same data set.  You can email them to me, or contact me, at jon.balgley@autodesk.com
Thanks.
Jon Balgley
guyh
in reply to: guyh
Hi Jon,
I have emailed you.  Thanks for the help.
Guy
AutoCADM 2011 SP2
ferrisb
in reply to: guyh
Was this ever resolved?
I'm having the same problem, with publisher 2012.
