I have 8 Publisher files that have apparently gotten corrupt after updating from Inventor. We performed the update and the update was successful. We made some minor changes and saved these files. When we tried to open them the following day, we get an error that says "Failed to Open File - Unknown Error. Please help!
Before and After datasets have been posted to Autodesk ftp site for evaluation.
John Weiss
CAD Administrator
Follett Corp
Solved by jweiss1313. Go to Solution.
Thanks to Jon and the Publisher team for fixing this problem for us. All our Publisher files are working great again!
John Weiss
CAD Adminsitrator
Follett Corporation
What was the fix for this issue? I have run accross this on a few of my publisher files when I went from 2011 to 2012.
We are working directly with individual customers until we can get a public fix released, probably in about four weeks. If you need this fix right away, please contact me directly at manjiri.mccoy@autodesk.com.
Manjiri McCoy
Software Developer, Inventor Publisher
Has there been any further progress on this as I am having the same problem.
Regards
Victor Pringle
Hi Victor,
We released a fix in our service pack 1 but later found that there are other workflow that exhibit this issue. We are actively testing a fix at this time. I would like to get hold of the ipb file that is causing this issue for you. Also if you know of the workflow that caused this issue that would be good to know too. If you need a ftp location to send the files please email me rajkumar.ilanchelian@autodesk.com
Thanks for sending the dataset Victor. I have repaired the file and send it back to you. As I mentioned earlier we are testing a fix for this issue.
I am still having problems with this issue on a new file. Has there been a fix?
The error occurs after making a small change to the Inventor Assembly files the .ipb is using. The Publisher file was saved before the changes were done in Inventor. The Publisher file now fails to load. A weeks worth of work is now down the drain.
I would have attached the files but they are too big to attach.
Regards
Victor Pringle
Hello Victor,
Can you please tell me which version of Publisher you are using? Also do you have all the service packs installed?
I can send you a dropbox account to share the file. Will that be OK?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I have Publisher 2012 SP2 (64bit) And Inventor Professional 2012 SP1(64bit) on 64bit Windows 7
Yes please for the Dropbox.
Regards
Have just got same problem on 2013 SP3.
Moreover, IP crashes on Export to DWF of the previous (openable) version of ipb (Autodesk Inventor Publisher has stopped working).
Sometimes it claims to have send some data* to Microsoft! ... not to Autodesk
WER6067.tmp.WERInternalMetadata.xml
WER7B28.tmp.appcompat.txt
WER8DBF.tmp.mdmp
May I ask you to share the file which have this issue to us?
Irene Chen (irene.chen@autodesk.com)
Publisher QA
Unfortunately files contain IP, thus can't be shared.
Do you have any "user instruction" to folow in order to repair file without sending them out?
Could those dump files be of any value?
Seems like quality decrease of Autodesk software becames critical.
Our company start to seek for altrnative now.
I am really sorry you meet this issue.
You can let me know the mail address and then I can send you the request to share the file just to me. we need the file to do the investigation to get the reason why this happen since this issue can't be reproduced at my side.
Irene
If you can't share the file to me, then could you please let me know the real steps to reproduce this issue?
-Irene
I can't remember any special steps.
IPB file tahat is now can't be opened was just saved.
I mean of course there were some modification to storyboard mada in comparison to previous (health) version of file.
But as soon as my steps were not video-captured I can't say what they exactly were.
For us it looks like we can't open correctly saved file.
Thanks for the quick reply, we will continue to keep tracking this issue, if you have more detail information to reproduce, please let us know.
Irene Chen
Publisher QA
May I ask what was the root of the problem in previous releases?
How those files were fixed?
