I usually work with Inventor files. This is the first time I tried to open a Solidworks SLDASM file in INVPub2012. What am I doing wrong? I do not understand what the error message is telling me when it states, "Failed to create InventorServer object." Thank you for any help.
the message is related to the fact that non Inventor files (like Solidworks) need to be translated using Inventor Server.
Do you have other versions of Inventor installed?
Is it possible for you to reinstall Inventor Publisher2012?
Lucia Casu
Inventor
Could you tell me the version of Solidwork file?
Maybe this error is becasue the Solidworks version is higher than inventor publisher version. Just like in publisher 2012 we can't import the file which is created in inventor 2013
you also can install a lastest inventor publisher to try again.
Thank you
Na Miao
Interesting. The Solidworks file versions are 2013 and up and it looks like the company will be moving to 2015.
Hi Terry,
we use InventorServer to translate most of CAD files, just like Solidworks,AutoCAD, Inventor and something so on. InventorServer will be loaded everytime when you try to import these files.
But some file are not translated by InventorServer, like dwf files, sktechbook files .....you can import dwf files is because dwf version is not upadte for long time, so the lower publisher verison also can import it.
I strongly suggest you update your publisher to 2015, in Publisher 2015, we support update from solidworks file, if you always import solidwork file, I think this will be very usefull for you.
Thank you
Na Miao
Had my company purchase INVPUB 2015 and I get a different insert error: Could not find the valid 3D geometry data in file when opening a Solidworks 2015 SLDASM file. See my lateest post.
