Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Color palette in Inventor Publisher
3 REPLIES 3
944 Views, 3 Replies
Hello!
I have a question...I want to change the color of the model I use from Inventor. I use a style created by me with white areas and thin black lines. To show which part to assemble I want to use a diffrent color to highlight the part. The color from Invetor doesn't work.
I have a color palette my employer want me to use. To be able to get exacly the same color I want to be able to wright the values RGB or CMYK. Is this possible or is the color wheel the only option?
Best Regards,
Gisela Svensson
Technical Communicator
3 REPLIES 3
coreyparks
Click the Style button on the ribbon bar.  Close to the bottom of the window that opens select create new style.  There will be a small box next to the word "color" click that.  When that dialog opens select the "Define Custom Colors" bottom at the bottom.  You should now see field where you can enter exact values for the RGTB settings.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
in reply to: coreyparks
Thank you so so so so much!
Merry christmas and a happy new years to you!
coreyparks
Merry Christmas to you as well and glad I could help out.
Corey Parks
