Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Cannot Manually Explode (Move) Single Instances of parts
3 REPLIES 3
marshallw
833 Views, 3 Replies
Has anyone else had problems selecting individual instances of parts for some form of editing mod? Please see attached ZIP. Am I doing something wrong here?
Autodesk Inventor Certified Professional
Autodesk Inventor Certified Instructor
3 REPLIES 3
Jon.Balgley
in reply to: marshallw
The short answer is that you cannot do this, on an inserted IAM file, because (presumably) the part is a component of a subassembly that is instanced several times. Publisher currently works on the subassembly's "component definition" hence all instances are affected.
The only workaround is to export your Inventor assembly to DWF, and then insert the DWF file instead of the IAM. DWF does not have a concept of a "definition", hence does not behave this way (each subassembly is independent, even if identical).
The biggest (only?) downside of this workaround is that you cannot take advantage of Publisher's "update" mechanism.
As a separate point, note that you cannot explode a single part, only an assembly or selection-set containing multiple parts. The parts are exploded away from each other, so "of course" you cannot explode just one.
Jon Balgley
samantos
in reply to: Jon.Balgley
Please apply for Beta testing.  Software is available now!
http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Beta-is-now-available-testers-wanted/td-p/...
-Sam
Sam Antos
Autodesk, Inc.
But why can't you even turn off visibility for the separate instances?
It's bad enough that you have to move them together - Or should I say you can't - because you move 1 and they all move, but if you select multiple to move - it fails to move any.
