Inventor Publisher
Inventor Publisher
Active Contributor
3 Kudos
Post 1 of 5
Callouts balloons and detail views losing attachment
971 Views, 4 Replies
08-21-2012 01:35 AM
Publisher 2013 SP2 I am getting callouts, balloons and detail views losing their reference on the part and pinging off away from the model when I hit save or export an image or video. It doesn't happen all the time, its ok when the components haven't been moved much, but if I have anything more than a simple unidirectional explode the issue is very prevalent. This is quite a serious glitch are there any workarounds or workflows you would recommend, and is this likely to be fixed in SP3?
Many thanks
I think i have find a way to solve the problem!
If i always choose parents (the green square) when i place the callouts, even that just is a part or from content center.
works for me right now.
Active Contributor
3 Kudos
Post 2 of 5
Re: Callouts balloons and detail views losing attachment
08-21-2012 01:48 AM in reply to: CadlineSupport
I have the same problem! some times the will get back in place after saving, sometime they don't.
Really frustrating.
Active Contributor
3 Kudos
Post 3 of 5
08-22-2012 07:30 AM in reply to: CadlineSupport
Active Contributor
3 Kudos
Post 4 of 5
08-22-2012 08:01 AM in reply to: timmy.stalnacke
Hi Timmy,
That seems to work! Even if you actually select the same part, just using the 'parents' option. Outstanding work - thanks for this.
Active Contributor
3 Kudos
Post 5 of 5
10-10-2012 07:28 AM in reply to: CadlineSupport
the problem i gone in SP3
Best regards
Timmy
