Good Morning,
As I said in the title... Autodesk Inventor Publisher 2012 doesnt work at Windows 8.1, and why?
Can someone send some fix?
It just appear an "Catalyst error" when I try to open it... and I dont have any Catalyst graphic card or something like that... Its all Intel...
Autodesk Products are not yet conpatible with windows 8.1. Some people say service packs corrects the issue and other people say they had to restore the windows update back to 8.0.
Best place to start looking would be here: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=Windows+8.1
Have you tried to run it in compatability mode for an older version of windows? Just a thought though I wuoldn't be hopeful that it would work.
Hi, I was fortunate to find a "partial fix" for Publisher 2012 running in Windows 8.1 from Chris Mitchell in the AutoDesk forums for Inventor AutoCad (not Publisher). I have been able to follow Chris' instructions and start Publisher 2012 in Windows 8.1 and actually create the 3D renditions for publishing that I needed.
Hi Terry,
I’m not aware of a fix for Publisher 2012 on win8.1. You could try the same file fix manually that works for Inventor.
Instructions to “install” this fix. Please follow carefully:
I don’t know if this will work or not – if not then the only other option is to ask the question in the Publisher specific discussion forum.
Hope this helps,
Chris
Sent: Monday, July 28, 2014 10:52 PM
To: Chris Mitchell
Subject: Is there a Windows 8.1 fixed for Inventor Publisher 2012?
I own a copy and would very much like to use it with my new Lenovo i7 with Nvidia graphics card. And yes, I am a Autodesk community member since 2011.
Message 5 of 21 (12,328 Views)
Re: NOT WORKING WITH WINDOWS 8.1
10-24-2013 03:55 PM in reply to: autocad.phil
We are issuing dll's that will fix the win8.1 issues for Inventor 2012 & 2013, on a request-only basis at this point. Official hotfixes will be released in the coming weeks.
If you need the fixed dll's then please contact me directly as there are some very specific manual install steps required.
Chris
Chris Mitchell
Inventor Customer Engagement Team
Autodesk, Inc.
Hi Terry,
The reason you see those errors is that the dll I sent you was compiled for Inventor & not Publisher. There is no official support for Publisher 2012 on win8.1 so this is really the only option right now; hopefully there are no other bad side-effects.
Unfortunately Office 360 is not supported with Publisher 2012 & I can’t find any workarounds for that. Someone else may have been ingenious so it might be worth asking your question(s) on the Publisher forums:
http://forums.autodesk.com/t5/Inventor-Publisher/bd-p/405
Chris
