Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Associate property to a subassembly
1 REPLY 1
will_hebden
539 Views, 1 Reply
Hi
I am currently using Publisher 2012 sp2
I am having difficulty placing a callout with an associated property onto a sub-assembly, all I can seem to do is select a part within the sub, and therefore referencing the parts property instead of the subassembly.
Is there a way to select the sub assembly and reference it's properties? If not, has this been addressed in 2013?
1 REPLY 1
irene.chen
in reply to: will_hebden
In Publisher, you can select Structured option in insert options dialog when insert file. And click Parts List command in the Ribbon, in the "Create Parts List" dialog, you can choose "All Levels" or "First Level Only" sub.
It is same for PartList between 2012 and 2013
Irene Chen
