Inventor Publisher
Active Contributor
rich-s
Message 1 of 6 (724 Views)
Appearance Style
724 Views, 5 Replies
03-08-2012 10:51 AM
Ok so I've made a custom appearance style, but how do I save it so I can reuse it vs. having to recreate it every time I start a new publication?
Employee
TimeraAutodesk
Message 2 of 6 (721 Views)
Re: Appearance Style
03-08-2012 12:23 PM in reply to: rich-s
Hi Rich -
Currently, there is no way to copy custom appearance styles between projects. The custom styles that you've created are only available within the project they were created in - this is currently as-designed.
Timera Hart
Active Contributor
rich-s
Message 3 of 6 (718 Views)
03-08-2012 12:28 PM in reply to: TimeraAutodesk
I was talking with my reseller and they suggested the following;
1. create a project with all my customizing
2. save as "template.ipb"
3. to start a new project, open "template.ipb" and save as "new_project.ipb"
4. erase all components
5. insert compoents
thoughts?
Employee
TimeraAutodesk
Message 4 of 6 (716 Views)
03-08-2012 12:32 PM in reply to: rich-s
This is a viable workaround, although you dont need to insert any components/data to set up and save an IPB file. I'd suggest just to cancel out of the Insert dialog that pops up when you create a new project, and then set up the styles as you need. This way you don't run the risk of possibly mixing datasets or anything in the future.
Timera
bowen192
Message 5 of 6 (686 Views)
03-20-2012 04:12 AM in reply to: rich-s
I too think this would be a great feature for a future update.
Valued Contributor
jberns
Message 6 of 6 (384 Views)
09-04-2013 02:51 PM in reply to: bowen192
Autodesk Team,
  • When will it be possible to copy Labels, Callouts, and Arrows between publications?
  • When will it be possible to export/import Styles (Appearance, Label, etc.)?
  • When will Zoom All (Extents) respect the Publish area instead of the application window?
Jerry
Autodesk Certified Instructor
Autodesk Inventor 2014 Certified Professional
