Inventor Publisher
Active Contributor
rich-s
Message 1 of 6 (742 Views)
Appearance Style
742 Views, 5 Replies
03-08-2012 10:51 AM
Ok so I've made a custom appearance style, but how do I save it so I can reuse it vs. having to recreate it every time I start a new publication?
This is a viable workaround, although you dont need to insert any components/data to set up and save an IPB file. I'd suggest just to cancel out of the Insert dialog that pops up when you create a new project, and then set up the styles as you need. This way you don't run the risk of possibly mixing datasets or anything in the future.
Timera
Employee
TimeraAutodesk
Message 2 of 6 (739 Views)
Re: Appearance Style
03-08-2012 12:23 PM in reply to: rich-s
Hi Rich -
Currently, there is no way to copy custom appearance styles between projects. The custom styles that you've created are only available within the project they were created in - this is currently as-designed.
Timera Hart
Active Contributor
rich-s
Message 3 of 6 (736 Views)
03-08-2012 12:28 PM in reply to: TimeraAutodesk
I was talking with my reseller and they suggested the following;
1. create a project with all my customizing
2. save as "template.ipb"
3. to start a new project, open "template.ipb" and save as "new_project.ipb"
4. erase all components
5. insert compoents
thoughts?
Employee
TimeraAutodesk
Message 4 of 6 (734 Views)
03-08-2012 12:32 PM in reply to: rich-s
Timera
bowen192
Message 5 of 6 (704 Views)
03-20-2012 04:12 AM in reply to: rich-s
I too think this would be a great feature for a future update.
Valued Contributor
jberns
Message 6 of 6 (402 Views)
09-04-2013 02:51 PM in reply to: bowen192
Autodesk Team,
  • When will it be possible to copy Labels, Callouts, and Arrows between publications?
  • When will it be possible to export/import Styles (Appearance, Label, etc.)?
  • When will Zoom All (Extents) respect the Publish area instead of the application window?
Jerry
Autodesk Certified Instructor
Autodesk Inventor 2014 Certified Professional
