Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Annotation callouts refernce parts and not top level assemblys.
2 REPLIES 2
lwaryan
390 Views, 2 Replies
Hello all,
I am new to publisher and picking things up as i go. I have the callout system to be associated to a custom callout that is in the model properties from inventor, however it does callout the pcmark but only calls out the part not the assembly. How can i get the callout to be the assembly instead of a part? when I inserted the model into publisher i went to options and made it structured. I tried setting up different custom properties for it to pull information and place it in that field but no dice.
2 REPLIES 2
na.miao
in reply to: lwaryan
  Thank you for reporting this issue.
Now we didn't support using the properties of assembly when create callout, we just support to get the properties of part.
I will  add this to our list, hope we will have this function in the future.
Thank you
Na Miao(Autodesk)
Inventor Publisher QA
lwaryan
in reply to: na.miao
Thanks for your input. That is unfortunate that it isn't setup that way. The way i have figured to solve this issue is to customize the BOM on inventor to add a new custom field pulling the information i need, then when i insert the model into publisher it will give me that option to associate the callouts to my custom field. Thanks again for answering.
