Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
adding annotations
3 REPLIES 3
mlstalter
369 Views, 3 Replies
adding annotations
Hi All,
 I'm very new to Inventor Publisher (2015) and have a very general question. Is it possible to add a drawing format to a snapshot? I'd like to explode and balloon assemblies in IP but also have our standard drawing format in the picture too. I'm using Inventor 2014 x64 for the models.
thanks for your consideration,
Mike
3 REPLIES 3
na.miao
in reply to: mlstalter
hi,
Thank you for using publisher 2015.
Publisher don't support insert inventor IDW file,but in publisher you also can explode it and add balloon.
If you still want the drawing, you can insert an image, but it doesn;t support update, you need insert a new image if you update the drawing file.
Thank you
Na Miao(Autodesk)
Inventor Publisher QA
bowen192
What sort of drawing format are you wanting to import?
mlstalter
in reply to: bowen192
I'd like to use our standard inventor drawing format.
Michael Stalter
CAD Designer
248-905-3779 home
mlstalter@gmail.com
