Inventor Publisher
Inventor Publisher
Distinguished Contributor
guyh
Message 1 of 19 (620 Views)
Added screws from CC in Inventor - Update file error in Publisher.
620 Views, 18 Replies
03-25-2011 05:59 AM
I am trialling Publisher and imported an INV2011 assembly fine.  Did some snapshots and then realised I'd let soem screws out of the assembly.  I updated the Inventor assembly adding 4 screw from the content center and saved.
Publisher picked up the file had been updated so I ran the update content and it fails with the message.
Update
    Failed to load assembly C:\VaultWorkingFolder\Designs\SOLEAL 55 DOOR\Single act double door\single leaf\Single Rebated Door.iam due to the problem with child files.
        File C:\VaultWorkingFolder\Content Center Files\en-US\ISO 7050 - C-Z\ISO 7050 - ST 4.2 x 25 - C - Z.ipt not found.
The file in question is located where the error says it doesn't.  Confusing me....
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
Board Manager
Jon.Balgley
Message 2 of 19 (618 Views)
Re: Added screws from CC in Inventor - Update file error in Publisher.
03-25-2011 10:25 AM in reply to: guyh
Got your message -- it will take us a few days to look into it.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Autodesk, Inc.
lama
Message 3 of 19 (589 Views)
05-03-2011 07:08 AM in reply to: guyh
similar issue.  using trial of Publisher '12 with Inventor Sim Suite '10.
Several assembly files won't open due to 'can't load file' error on content center files from c drive (i work on network drive, no vault)
Also a file that did open with custom content center fasteners has some of them hidden on publish.
Larry Marshall
2013 Product Design Suite Ultimate
Windows 7 Sp1
Intel(R) Core (TM) i5-2400 @ 2.00GHz
6.00 GB of RAM
AMD Radeon HD 6570
Employee
mccoym
Message 4 of 19 (582 Views)
05-03-2011 09:20 AM in reply to: guyh
I have some questions:
1. On import, are you setting the Inventor Project file correctly in the import options? We require it to resolve paths.
2. If you do set the project file correctly, does Import work, but Update continue to fail?
-Manjiri McCoy
Software developer
Inventor Publisher
Member
tizianokdg
Message 5 of 19 (562 Views)
05-05-2011 07:03 AM in reply to: guyh
Hello all,
I have the same problem. It seems that library files are causing the problem. I even can't insert an assembly.
Is there any one who could fix this problem?
Thanks is advance,
Tiziano Cannova
Employee
mccoym
Message 6 of 19 (553 Views)
05-05-2011 08:16 AM in reply to: guyh
Are you seeing the failure even after setting the Inventor project file (.ipj) location in the Publisher Import Options?
-Manjiri McCoy
Software developer
Inventor Publisher
Member
tizianokdg
Message 7 of 19 (536 Views)
05-08-2011 11:02 PM in reply to: guyh
Yes, the problem is even occuring when I set the project file right.
Tiziano
Employee
mccoym
Message 8 of 19 (526 Views)
05-09-2011 08:11 AM in reply to: guyh
Can you send me the ipj file if posible? please email me directly: manjiri.mccoy@autodesk.com
-Manjiri
New Member
jdukes1
Message 9 of 19 (500 Views)
05-17-2011 05:27 PM in reply to: mccoym
I am having the same problem with the trial version.
guyh
Message 10 of 19 (493 Views)
05-25-2011 01:24 PM in reply to: guyh
Ok I want to add to this... further tests are needed but I think I found the problem.  Publisher assumes the project file defines the CC file locations but if you have the project set to default then this information is not available to Publisher.  You therefore have to have this defined in the project file or have a project file you use only with Publisher.
Can anybody confirm?  An oversight by Autodesk if the case.....
PS I am still waiting for an invite to the next beta :smileywink:
Cheers,
Guy
AutoCADM 2011 SP2
Announcements
Need installation help?
