I am trying to make use of iLogic for the firs time and struggling a bit.
How can I pass name or path of active component in to a rule?
What I would like to have in the end is a rule that would make a given component or part not visible in all Design Representations.
The thing is I do not know in advance the name of the part or assembly so I cannot (do not want to) put it explicitly in the code.
Idea is that I would like to select part or assembly in a tree and then run the rule so to change visibility state of all occurrences of a given component in all design representations.
And I am stuck at the very beginning not being able to figure out how to pass active component to a rule.
In every online tutorial I saw components are defined explicitly in the rule code.
Cris.
Hi kmeldfreyssinet,
Have a look at this link, I think it will be very close to what you're after (although it uses LOD reps rather than View Reps):
I hope this helps.
Curtis
