two point center rectangle style
It would be nice if there were an application option that would allow the user to set the style that IV uses to draw a center pick rectangle.
Personally horizontal and vertical reference lines suit my style of sketching better than diagonal ones corner to corner.
6 Comments
it don't find the auto construction geometry usefull, it should constraint on the chosen point (vertical, horizontal)
drfleau
With diagonal lines, you can define a rectangle with 2 clicks. With horizontal; and vertical, you need 1 more click. I find diagonal construction lines far more intuitive.
andrewdroth
I think defining the rectangle could be the same procedure. A center pick and a corner pick. No need for another click.
stuartmp
Nice Idea, you could also add your own block of the shape you want to your template file, then just use the sketch geometry in the block.
MichaelIV
Like the Idea Smiley Happy
andrewdroth
