Show only
Search instead for
So when generating a tube & pipe run the part number is blank why? it should work the same as frame generator where the stock number and length are pushed into the part number so they merge if the same.
This has been a long running issue. Let's see if we can escalate this and get something done about it. Basically, no matter what property in the Content Center you map the Project.Part Number... or what you put in the Family template part in the Part Number field... Part Number in Tube & Pipe comes in blank on pipe spools. The fact that no settings make a difference tells me this must have been by design... so can someone please explain the reasoning behind it? I promise if it's logical, to be nice. 🙂
If it's not by design, can we get this fixed? It would be a massive time saver to nat have to manually edit each piping BOM and enter part numbers for hundfreds of pipe spools, when a simple expression in the family table could do the job.
This idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it. An updated Autodesk Inventor 2016 tube & pipe setting allows you to auto populate specific part numbers (such as; Inherit from Content Center, Use File Name or Empty) during creation/population.
