For those of us who do not use Auto Routes in tube & pipe, it would be very handy if the dimensions and constraints I plce in a route do not change unless I change them. Currently these constraints and dimensions can randomly change whenever I add, delete or change a fitting in the route. Once I have placed a dimension or constraint, I should at the very least be given the option of locking them so they cannot change if something else in the route changes.
Example: I want the corner of a route to be an exact distance from the edge of my machine frame, so I place a dimension from the endpoint of the route to a workplane created in the route using "Include Geometry". I then add a tee to that leg of the route, and the dimension I placed (as well as any constraints) are replaced by dimensions that Inventor places on the route. Inventor does not know my design intent better than I do, so I should have complete control over these dimensions and constraints... if they blow up on me, let it be on my head.
