Toggle thru orientations when placing to-be-grounded 1st part
I always check the option to auto-ground the first part when creating an assembly (though this user option still becomes randomly unchecked).  But depending on how the first part I place was modeled, the orientation selected by the program may not agree with what I wanted (i.e., part Front may not match Assembly Front).
It would be nice to be able to toggle thru all the possible principle plane orientations during (or after) placing the component while preserving the parts' grounded status.  I may be missing a trick, but it appears the only way to re-do a grounded component now, is to un-ground, constrain, and re-ground and unconstrain.  Being able to do the equivalent of Alt-Tab thru all the possible orientations would save some time.  As an aside, I wonder if this issue is why some folks don't like the auto-ground option.
3 Comments
kim.schroeder
There is an easy way to change the view orientation by redefining the Top or Front View;
I hope this will help you...
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
