I work in the UK, so around 90% of the threads I apply in Inventor are ISO metric, the remainder being BSP for pipe connections.
When I try to add a thread or a threaded hole, Inventor goes straight for the ANSI standard threads every time. I then have to manually select ISO metric threads which is time consuming when you have to create a lot of threads.
We can select various defaults in Inventor, such as units and standards, but no options for thread standards. Can we have the option to default to a particular thread standard in the Application Options?
It would also be helpful to have a checkbox in the relevant dialog box to select the option to 'remember last setting' so that Inventor doesn't head straight for the default if you have a lot of alternative standard threads to apply.
