The length of Flexible Hose should have a fix setting
When drive or move the assembly components, the length of Flexible Hose will change.
There should have a setting to fix the flexible hose's length, because after the design, you don’t want to change the hose length when moving the components.
10 Comments
WHolzwarth
Well, Solidworkers seem to be better off here.
http://help.solidworks.com/2014/English/WhatsNew/t_setting_fixed_length.htm
Walter
dan_szymanski
Status changed to: Accepted
Accepted idea [851]. Thanks!
rkeller
agreed. I think the ability to fix the length of the hose would be a great plus when you're working with moving components for example a front end loader or backhoe or a set of trailer brake hoses this feature would be great help
Having the ability to dimension a spline for fixed length would be a wonderful edition. Being able to measure total spline length and total loop length would also be very useful when planning for manufacturing hoses. This is a primary reason why I don't currently utilize Inventor for creating hoses.
Has a solution to this been worked out?
Chris
ChrisMitchell01
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute/validate then please apply for access using this link:
https://bit.ly/InventorBeta
Chris
Aadithya01
Hey Guys,
Few of our customers in our Region (Coimbatore , India) have recently started to ask for this feature and too bad to know that this functionality has not been implemented yet . Please please bring this feature at the earliest.
Regards
Aadithya
Application Engineer
USAM Coimbatore
Xun.Zhang
Hi Aadithya,
As Chris indicated above, just go to Beta program and you will find something surprise you more.
Aadithya01
@Xun.Zhang
Oh my god , I was really astonished to see the lock option for the hose length ... Can we expect this feature in Inventor 2019 ?
dan_szymanski
This idea has been implemented within Autodesk Inventor 2019. Special thanks to everyone who cast a vote for it.
