Inventor Task Scheduler can IMPORT multiple formats into Inventor but it cannot batch export to standard 3D formats (IGES, STEP, SAT, etc). As shown below, only DWG is an option.
I want to have the same CAD formats available to export in Task Scheduler that I am able to do in Inventor.
Solved by ChrisMitchell01. Go to Solution.
Task Scheduler based export is already supported. You need to select the desired filetype as shown below:
Thank you @ChrisMitchell01. Either I over looked that or it was not an option in Inventor 2014 when I posted this.
