Stretch Command in Inventor like in ACAD
It would save so much time if you could have a dynamic stretch tool so if you item grows or shrinks in size that you could just simply stretch it like we did in autocad. Some larger assemblies I might have to change dimensions in a couple dozen parts which takes a lot of time vs. a simple stretch command that would adjust all of the parts based on you making a a stretch and telling the function how far to stretch in which ever direct you want.
I know you can model and make items adaptive but I use the same parts in multiple drawings sometimes.
Maybe something like the mirror command where you can deselect some of the items when making dimensional adjustments.
Mike
1 Comment
10071482
I believe this function was in Inventor, I didnt use it much so I'm not sure if it would fit your needs.
I believe it was called Inventor Fusion?
