standard center holes
Please add standard (ISO 866, 2540 and 2541) centre drill holes to the hole dialog.
8 Comments
Diequa
and DIN 332!!
salariua
I have done them as ifeatures. But it would be nice to have them over.
Diequa
I don't know why this isn't in the program to begin with, even in shaft generator it should be there, you have din undercuts! Which should also be available outside of shaft generator too!
DIN 332 hole command can be used for both tapped holes and non tapped as a centering hole.
Tags (2)
BorisGorbulenko
And add it to Shaft Design!
dan_szymanski
Attaching image from Idea that was merged into this one:DIN 332 INVENTOR.png
liuw
这个功能在AutoCAD Mechanical中包含,甚至在MDT2009中早已实现,但在Inventor不存在。中心孔是设计轴类零件经常用到的,对专业设计用户来说必不可少!
zourh
顶起!
kosvkv
Community Visitor
Hello, when you add this future ?
