Sometimes it is easiest to create a pattern of holes in inventor using a sketch of points. The pattern may not be perfectly rectangular or circular. It would be useful in the assembly level to be able to fill these holes using the feature command and filling these holes based on the sketch. The command would create a pattern by filling each each of the sketch points with the part that is being patterned.
