Reverse zoom option for Inventorview. (viewer, not main program)
Inventor has an option to reverse the zoom direction, i would like to see this added to the viewer program "Inventorview".
See topic: http://forums.autodesk.com/t5/inventor-general-discussion/inventorview-zoom-direction/m-p/5221433
It would also be nice to have a configuration / setup menu in the viewer for controlling any options.
4 Comments
karthur1
Having the zoom reverse option would be a welcomed addition for any Inventor user.  While you are doing that, why not make all the view controls that we have in Inventor available in Inventor View also?  The thing I miss the most is the "orbit center" and F4 for the orbit shortkey.
t.bennett
I'm not sure if InventorView is what is used in the Vault to preview files but this option would be nice there also.  Not sure why it is reversed from the Inventor default...
t.bennett
Also, 3Dconnexion devices do not work in Vault preview or InventorView.  No idea if this is an Autodesk issue or 3DConnexion issue.
-niels-
@t.bennett I don't believe Vault uses the same viewer, so it's probably best to make a new idea post for that. (vault has it's own ideastation: http://forums.autodesk.com/t5/vault-ideastation/idb-p/2 )
As for the 3Dconnexion devices not working in vault preview, it works for me but rotate starts behaving weird after i move or zoom.
So that might be a 3Dconnexion driver related issue.
