I think it would be great if it were possible to only retrieve selected hidden lines the very same way you can retrieve dimensions in your DWG. Currently, you can turn them on, but you get everything. In some cases, it is beneficial to see only "4" hidden edges instead of the entire hidden assembly, every hole, chamfer, fillet, etc
