Customers need an option in the sheet metal style with the one in the following configuration setting in the corner
The circle for the exemption can always place correctly on the intersection of the (blue) bending lines.
This is achieved only at frame 1. (Thickness * 4 ul)
If the size of the exemption changed, the circle of the exemption is no longer correct at the center of the bending lines.
Customer need a option to close the gap from midpoint circle and intersection bending lines.
Thanks!
