If you have an existing sketch block then you can add lines to that block [ADD TO BLOCK]. But cannot de-add them so they will be out of the block and back in the upper sketch.
AutoCad has this functionality.
They call it: "Add to working set" and "Remove from working set"
Don’t understand why Inventor only can add lines not de-add or remove them.
