Since Inventor has real-time ray tracing and Inventor Studio is of little use, I suggest the following...
- Interactive - When ray tracing starts, I immediately change to Good because the Interactive lighting is so different from what you see in Good or Best, it seems of little value to me. I work in Shaded view mode until I'm ready to produce a "pretty picture".
- Good - I use this to get a sense of what the ray tracing might look like. The time cost is proportional to the purpose for which I use it.
- Best - One suggestion mentioned in another thread is rendering to a file instead of to the screen. Interesting option, if you pursue that, have the output go to the filename with a number suffix.
- Best - When I take the time to render a Best solution, it is for one purpose only - OUTPUT A PRETTY PICTURE. It is really annoying to have to wait AGAIN to go through "Generating offscreen image". This seems costly in time and redundant, the real time render just completed. How about an option to save the screen image output at the same time. Then I pay the render price only once.
- Default Settings - While I "get" that the output image size isn't specified until Save Copy As, it seems to me these are settings that people use infrequently and could be application options. I usually decide on a pixel resolution (e.g. 2400 x 1600, or whatever) for a project and stick with it.
- Default Settings - It would be nice to have a DPI/PPI value - start at 96 ppi - screen resolution and go up from there. Set that information for a project/session once and get on with it. If deemed necessary, the Save Copy As > Options dialog box can have the default values editable so they can be overridden.
