Lock View in Moldflow functionality has been added to this.
---Description---
1. To be compared (or similar) to open parts one after the change to the cascade view
2. Running Lock View
3. If you rotate the parts which other parts of the same window also rotates
If you add this feature,
When you create a design change data, or can be checked directly in the design geometry.
Thank you.
