"Implemented" Symmetrical Constraints That Actually Work!
Now I just hope this Idea isn't just discarded as "Duplicate" without at least being looked into.
I am currently on Inventor 2014. I am very used to using Symmetrical Constraints from my previous work place. So much so that I used them ALOT! They are very useful especially in assemblies that are in a "working progress" state, because these types of constraints, when they work properly, allow easy editing of assemblies and also allow the reuse of assemblies for projects of different dimensions.
However, even if the constraint is present in Inventor 2014, I can't get it to work.
I would like the mid-plane of these two identical tubes to be symmetrically placed on either side of the original assembly work plane. All XY planes, it can't be any simpler. At this point there are only two components in the assembly. And they are both constrained by their other two original work planes to the original planes of the assembly. There are only 4 mates in the entire assembly, Part YZ to Assembly YZ and Part XZ to Assembly XZ. Also there are no grounded parts. Each part is free to move in only one direction as indicated by "Degrees of Freedom". This SHOULD work.
Ok, "Place Constraint" window opened. Symmetry selected. 3 selections to make.
First selection = XY plane from Part2:1 -> Second selection = XY plane from Part2:2 -> Third selection is the "Symmetry Plane" = XY plane from assembly. When "Apply" is clicked, this is what I get.
Now I haven't yet placed a distance between my two tubes. This constraint should work before or after a distance has been determined. So let`s try again but this time placing a distance between the tubes, (the Flush,) which changes nothing to their degrees of freedom, only that the two will move together. Regardless, the "Symmetrical Constraint" will not function. The best I can do is to accept the error and have a popup reminding me of the error at every operation.
Has anybody else out there ever successfully placed a Symmetrical Constraint?
