Show only
Search instead for
I assume you mean, "Make Inventor not allow a right side view to be moved to the left side of the front view, etc."
Perhaps instead of not allowing it, we could change the behaviour of it. I also assume that your reason for posting this is because you have yourself, or seen others, unintentionally place a view out of projection. If Inventor instead actually changed the view as users expect, would that be better? i.e., if I slide a left hand view over to the right side of the front view, should Inventor change that view to a right side view?
Yesthat's the idea: Do nothavean error in theprojected view. It seemseasier tolockthe move,than changingthe view.(Especially ifthere are alreadyannotations)
Great Idea....Many times when I do a copy design and then open the idw's the projected views are moved. Sometimes they are on top of the parent view, which makes it easy to spot. But sometimes, the projected view is all the way on the wrong side. I have to watch this closely cause it can cause problems in the shop. I would prefer that if the view was moved to the opposite side, it should change to the correct view... and keep the dimensions, of coarse.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
