Positioning an Hole from an existing hole
Increase the method to positioning an hole selecting an existing hole.
2 Comments
mikeh7
Wish I had years ago and still need badly.  To expand a bit what I'd like to see is select an existing hole, input a distance an axis to pattern the hole parallel to.  The hole selection would dictate the face/plane the hole gets created on.  We can't do just a pattern as we want the hole to be another size.  Currently we have to create a sketch w/ points then create hole feature 1, then share the sketch and create hole feature 2.  Alternatively we can create sketch 1, generate hole 1, create sketch 2 w/ projected center from #1 and establsh 2nd hole location and size.
Originally submitted on SR 1-1187563861
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
