pointcloud shape recognision Inventor
I would like to see a feature which could recognise shapes in Pointclouds.
right now there is only an option to import a pointcloud in inventor (Factory Design Suite) If I want to adjust an installation which is scanned by a 3d scanner I need to draw the entire installation from a pointcloud. If shapes could be recognised by the software and could be transformed to a solid, it would save a lot of time.
all geometric data is provided by a 3d scan. if selected several points, it should be able to create a mesh or solid from the points position.
Competitor software already have this feature. plugins for several autodesk software is already available, but not for inventor
an example of pointcloud to solid recognision found on youtube:
after recognision:
hopefully more inventor users will see the advantages of this feature
regards
Niels Pippel
4 Comments
jasonm
This would be a fantastic addition, I have a faro focus 3d scanner and the chance to add some functionality to inventor , similar to rapidform / geomagic designX, would be a huge step in the right direction.
Hi Jason,
that's what I was thinking, hopefully with some more kudo's they would pick this idea to put it soon in a new inventor release.
asiu
This will be a nice addition.
Autodesk is getting more and more into manufacturing and 3D printing.
We are at the point where we need this kind of tool to be able to make better use of the scanned data.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
