Pattern Instance Rotation
It would be nice if there was a feature that allowed you to ratate pattern instances. Say if do a rectangular pattern of a slot (5.5x40.5) at 100mm instances but rotate each instance angle slightly more than the previous, say a degree per instance so over 45 instances it would have rotated 45 degrees on a single vector or path.
3 Comments
mrattray
How owuld this be different than a circular pattern?
S.Bethune
because its a rectangular pattern with an instance revolve option not a pattern about an axis.
I have manually drawn what i required as shown below.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
