Pattern Enhancement Suggestions
I would like the patterns in parts and assemblies to be able to:
-stagger the holes/bodies
-be able to roate the seed at a given angle (hole/body)
-use closed contours to determine the active/suppressed holes, in other words to fill the contour with holes/bodies
-establish a clearance to the contour (positive or negative)
3 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
drawings
Should be merged with other pattern ideas concerning borders. This expresses it simply.
