Hi guys,
This is a double request,
1. I want to pattern an assembly component based on a Curve, just like how you would pattern a feature in part modelling.
2. Since the first one cant be done, I would like to used patterned Work Points as a reference for patterning along a curve, but unfortunately, the Feature Pattern Selection does not allow Work Point selection
Currently, I have to create patterned solids/surfaces as references in order to pattern a component along a curve. Hence I believe there is room for improvement here.
Regards
Ilyas
