My company regularly puts additional model information inside of drawing dimensions, for instance "31 SPACES AT 7 3/8" = <<>>", where 31 and 7 3/8" are parameters that would need to come from the model. Unfortunately, you cannot access the parameter's custom formatting from the dimension text editor. You can insert the parameter, but that is always the decimal version in base units. It would be nice if the iProperties were accessible from here or if the parameters had an option to place the custom formatted version. This functionality is available when placing a note on a drawing, so I imagine it wouldn't take much to allow this in a drawing dimension as well. Thanks!
