Eliminate the Need for an IPN File
If the only purpose for an IPN file is to create an exploded view, why not incorporate the tools needed to make an exploded view right into the assembly files.  This way there is no extra files created.  Then in the drawing you could have an option in the edit view dialog to show the view exploded based on the exploded configuration in the assembly.
8 Comments
Dan_Margulius
I want to explode my assy directly in the assembly environment without needing the ipn.
IPN has problems with big assemblies, harness , design views and in general it adds more files for me to manange.
No need to have IPN, do it in the assembly directly. It is so much simpler.
Dan
mthomas
or even better scrap the IPN and include Inventor Publisher in the Suite (although it needs large assembly performance improvements first)
jletcher
I don't like this idea.
1st most large assemblies have subs that should be exploded on their own.
2nd most assemblies are large in size (not file size) but dimensional and a exploded view of this size would be a dot in the drawing.
3rd the file size of the assembly with an exploded view built in would be huge and take forever to open. so the next thing you would complain about is it takes 10 minutes to open an assembly.
Dan_Margulius
I hope Inventor Publisher will be inside the Suites,
I doubt it though because Publisher is going to the Cloud.
Dan
MattH_Work
Position Reps could be used to produce an 'exploded' view.
How about giving us some extra 'tweak' tools within the Assembly environment to facilitate the exploding proccess, tools designed to replicate the IPN environment (I 'could' do it by overriding contraints but that would take to long), give us tools to drag components and capture the resulting position (just like tweak in IPN)
smithar
Status changed to: Gathering Support
JoeBarnes4076
This could be a huge time saver and get people to use it more.  Some users avoid using because of the extra file to manage and reference.  Presentations should be just another sub-node in the representations folder
danmachen
@JoeBarnes4076 - Nice work on the model tree suggestion. I think this would be a welcome addition.
I have also noted that using vault & Inventor rename functions seems to not work correctly with some ipn files.
If they incorporated this functionality into the 'presentation views' as you suggest it would be great and save us that extra file to manage and uprevise.
