More Intuative Exploded Steps
When creating an exploded assembly, I noticed when I would tag and move either on part or a few collectively that they would move together, which is what I would expect, but when I select "clear" to start a new explode step, if I had to go back and move those previous groupings of parts, I had to do it individually either by adjusting the distance value, or create another exploded step tagging them all again.  What a royal pain!!!!
What should happen, is after I have been able to create an exploded step, if I need to adjust its distance, RC on one step (that highlights/grabs all parts involved) select "Edit" or "Redefine" and it allows me to adjust all parts involved.  Instead of individually.
This process should be made simpler then what currently exists.
4 Comments
I agree. This should be simpler. If you can , please implement this change as soon as practical.
asiu
Hi Cadmanto,
I agree that there are lots of improvements needed, but you can make your life easier if you use the "Filter". Click the icon shown in the picture below:
You can toggle from "Assembly View" to Tweak View or "Sequence View". Read more about this functionality in the help.
You'll save a lot of time and more importantly aggravation.
Good luck!
Cadmanto
I know about the filters.  I saw that in another posting.  Thank you for mentioning it though.
I just know (like you indicated) this process could be a whole lot easier.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
