Show only
Search instead for
As in another idea in the ideastation: please combine the vault an the part/assembly browser
design doctor is not optimal at the moment (no work flow for many errors) -> browser pane for all errors - hovering over the error highlights the problem or the affected parts
vault file browser with search -> open parts or drag and drop them direct into you design.
workspace-browser with search -> open parts or drag and drop them direct into you design.
All panes should be...
accesssable through tabs not through the actual drop-down
undockable from the main pane to place them across screens.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
