Mesh to Solid Tool
Mesh to Solid Tool
It may be a big ask but howabout a real tool to convert mesh data from an STL file, etc to a solid simply to use the item as a placeholder. It would then be possible to slice it and use the sketch sections for surface lofts or even a new parametric model. The current mesh enabler add-on is limited in capability.
An even bigger ask would be for a full reverse engineering application that detects planar surfaces, holes, revolves, etc to create a full parametric model from scan data.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can base on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
