Slice Graphics - Update
The slice graphic uses a default slice texture. It's looks like concrete. Sometimes it's also easy to use the software Snagit for a quick screen cut to show specific details. The existing standard texture is blurry. It should be easy to choice different hatches to improve quick presentation pictures. I have seen somewhere how to change the section texture but it should be done in an easy way by drop menus.
I have added this idea for a couple of months ago but it was not possible to update the text inside the idea.
27 Comments
kstate92
Instead of forcing your customers to make a scary registry hack per this nonetheless very helpful article: http://blogs.rand.com/manufacturing/2010/11/inventomizations-slice-graphics-pattern.html, make this a User Option within the application.  Not everyone (anyone?) needs a concrete pattern on their part cross-sections.
A truly proactive and forward-thinking company would also add the option to tie each part's cross-sectional pattern in the modeling environment to the part materials' cross-hatch pattern used in the drawing environment.
Tags (5)
Cadmanto
The default should not be concrete, but rather no texture and have the option to add one if it is necessary.
SteveEn
Tags (1)
SteveEn
Picture added i the window.
michael_marx
It´s possible to define an own texture for capping.
You have to define a new entry into the registry where the colorschemes are.
the entry is named "SliceCapTexturePath" with the path to the own texture.
I use a trasnparent texture to easily look inside the parts and see the collisions!!
spackle42
Wow! There have been posts on the forums regarding this for ten years. I can't believe this has only been posted to the Ideastation so recently.
mrattray
The Idea Station is a recent thing. It's only been around a year or two.
EDIT: Also, this is a duplicate (or there's duplicates of this...).
ad64
Also please add an easy option to show each part's actual texture instead of the concrete texture with distinct lines between two adjacent parts of the same texture.
http://forums.autodesk.com/t5/Inventor-General/Real-Cross-section-textures/m-p/5129408#M513908
Steve
spackle42
MikeSmell_ADSK
User would like to be able to control the color and style of shading that is used on the faces of a section view. Currently, a textured look is given to the face and the user has no ability to modify this visualization. See the attached image.
Tags (1)
michael_marx
stuartmp
I agree it would be good if you could select different textures maybe even per part.
You could mouse over the texture of one part and then a menu appears were you select a new texture.
stuartmp
dan_szymanski
Status changed to: Gathering Support
Hi Steve, It looks like you accidentially logged two identical Ideas due to limage linking issues.  I am closing this as a duplicate of the Master Idea here:  http://forums.autodesk.com/t5/inventor-ideastation/slice-graphics-update/idi-p/5057304  Thanks! -Dan
michael_marx
i want to be able to switch different textures in slice view eg. like the behavior shaded views with and without edges displayed
standard
switch to user defined texture
switch to transparent
and rework the highlighting when in capping mode
also visually slice the highlighting of the parts
and be able to measure the sliced faces
andrey1962
can be add as variant "Fill Hatch" with part color
stuartmp
I agree, the standard texture use has been a problem/ ugly since the first release.
Sent from my Android device
sergio.missori
Designers in my technical department were complaining about the bad look of solid cross sections. I have found on the web a way to "hack" the setting and use a more classic x-hatch. It works and designers liked it.
Unfortunately it requires to apply changes to all local machines and you need Administrator privileges.
An option to choose the texture to display in cross sections or even associated to the material wholud be appreciated.
dan_szymanski
Idea added to backlog for future consideration [570]. Thanks!
Kazu-Kei
It is difficult to deal with many situations with less expression.
A function that can change to the optimal display is essential.
