Items from Vault that are not checked out should simply be read only.
How is it that if I close an item that I am not checked out that I can save that item?
Worse, why is it that Inventor incites me to save items that are not checked out?
It is a pain to constantly keep an eye on what Inventor wants to save and always be watching close so as to not save items that I wish were read only.
Let's say I am working on an assembly. In this assembly I have new parts that I have created and are checked out. But I also have parts that are reused, are not checked out and should be in read only form.
As I work on my project, I often need to "consult" the parts that are reused in order to create my new parts. I do not wish to change the old parts in any way. The old parts are also used in other projects and any change could be problematic.
But, since these parts are not read only, although I think they should, Inventor often thinks I changed something by simply looking closer at a sketch or whatnot, (in order to open a sketch I need to hit "edit sketch") and at the end of my session Inventor will prompt me to save items that it very well knows are not checked out because it will even warn me.
See example on "Save Prompt.jpg"
In this example, the list is short. Sometimes after several hours of design, the list can be a pain to sort out what should and should not be saved.
The situation is even worse when several designers are all working on the same project at the same time because we are all modifying different areas simultaneously which are co-dependent. (The height of your part will affect the height of mine but the length of my part will affect the length of yours, ect.) Not only do you have to keep an eye on what is being saved, but also on what is being updated from the vault.
God forbid you missed an item from the list illustrated on my "Save Prompt.jpg" and you are trying to update from vault things that should be read only. You get another prompt warning you that " File 'filename.iam' is NEWER than the data in the vault. Are you sure you want to overwrite it? " In this case you don't even see a list, you just go one at a time with a prompt for each file or hit "Yes To All".
I just think that things would be so much easier if the save option for things not checked out was just not there.
You could have a prompt warning you that you are read only when opening a file, just like the already existing prompt giving you the option to checkout an unchecked out file.
