Upon editing text in an Inventor drawing via "Format Text", if any typographical emphasis (bold, italics, underline) or other font changes are modified on the text, instantly that text is no longer tied to the attributed style ("Note Text (ISO)" for example). Inventor however still reports that the edited text is indeed actively referring to a style, when in fact it's not.
I propose a simple tick box, that when any typographical emphasis is engaged on text that a tick-box called "Style Override" engages automatically, which clearly tells the user/editor that the active style is being overridden.
If these "Format Text" manual changes need to be removed at a later date, all that's required is for this tick-box to be de-selected, and the text will again return to its designated style. To further assist this particular workflow, for multiple text entries that need to return to their original style, they could all be selected and then from a right click menu "Style Override" could be disengaged, returning all selected text to their original style.
Are there any further thoughts on this idea? Good, bad, ugly?
