Insert parts into a specific "level of detail' in an assembly
When inserting parts into an assembly, they will show up in every level of detail (LOD) until they are suppressed inside each LOD.
For instance:
Assembly A is a piece of equipment and has 10 LOD's showing different tooling used.  If Part X is inserted into Asm. A it shows up in all 10 LOD's.  Part X needs to be manually supressed in each LOD if it is not needed.
It would be nice to have a drop down list for Part X that would allow you to pick which LOD's it would be suppressed/unsuppressed for.
4 Comments
Same request but for constraint/features in different position views
WillMorganmhs
Even if it just defaulted to only unsuppressed in the LOD you place it in, that would be an improvement.
karthur1
Anything would be an improvement in the way LOD's (and dont forget view reps) are handled now.
rychetsky
In SolidWorks is possible to work in this way if you place new part into the assembly.
